How Many Project Planners?
Does anyone have a guide as to how to scope the requirement of Project Planners accross a portfolio of projects of varying sizes.
I understand that size & complexity of project and the level of service provided will be influensing factors, but is there a rule of thumb maybe in relation to the number of project managers.  1PP to 1 PM  or  1PP tp every 2 PMs maybe?
S
Shah. HB 👤 Member for 17 years 7 months
Hi Philip
I believe it depends on project requirement ,2 or more it depends on the nature of project complexity and contact value
Shahul
M
Hi Philip
This is an interesting question.
Some projects are lucky to get any planners at all.
To define terms - a Planner knows how to build the project - a Scheduler knows how to work the software - sometimes the Planner can do both.
The ideal situation is where a planner creates the programme and then monitors the site progress - probably using a team of assistant schedulers.
A large and complex project may need more than 1 scheduler and 1 scheduler may well be needed to spread over several simpler projects.
The difference between what is needed and what is actually allocated is the main point.
Other factors include:
1. Skill speed and accuracy of the Planner / Scheduler
2. Chosen software - the ability to copy paste between spreadsheets means that data entry can be done in seconds or takes hours of manual input.
3. Company systems and procedures - if a lot of data reports are required - EVA S Curves etc - it will take longer to do than a simple progress update.
4. Form of contract - working on a NEC project will require a lot more planning / scheduling input than - say - a JCT.
So if anyone has a rule of thumb that will encompass these factors I would like to see it.
What happens in practice is that the minimum number of staff are deployed - up from zero - and only if they are really struggling will extra suport be deployed.
GeoVe
Johannes Vandenberg
Soheil Barekat
Peter Holroyd
Neil Atkinson
Trian Asmoro
Erkan Polater
Luis Jr Ngade
Ben Welsher
