Project Control Procedures
Erim INANC
gorilpk
Ricky
pinoyplanner
Siddharth Ranadive
Aidar Kurmantayev
Dave Morgan
blake333_
Mohammed Netarwala
Moahmed
If your comany has hired 2 lots of (presumably expert) consultants to do this, and were not happy with either output I would:
-Tell them that if they insist on only giving you a month to do this, they wont be happy with your output either.
-Ask for copies of the previous consultants reports, and detailed comments as to what they didnt like about them.
-Better yet, ask them for a URS.
PMBOK would be my suggestion for basis of project control procedures, but I would expect the previous consultants to have followed a similar path with little success.
Good luck -I dont envy you!
You can do this way also .......
you can divide your companys bussiness operation in the following phases..
1-Initiation
2-Planning
3-Execution
4-controlling &
5-closing
list up all these phases in vertical column and then
list up all the reelvant department horizontally (you can interchange ,as convenient to you).
Now u have a chart for you to insert your companys process ,against each phase and below each department .....
means ....in which phase which department has what role .....once you put all of your process in the chart in right place ..then you have to link all the proceesses with each other in a manner it happens in your organization .
You can use MS VISIO software or smart draw(we use MS visio ..while i have just see the smart draw .)
I dont know how far it suits you ..anyways this is how we do in our organization .....even at group level ..
Rgds
Khawaja
Hi Sajid,
Yes they are. The information that they have is very good.
It depends on the size of the project that you have and its complexity. You need to spend some time adjusting them to your needs.
You should also read their newsletter. Very useful information to read from time to time.
With kind regards,
Samer
Hi Samer
What do you think about using Method123 standard templates for documents & forms? I found them very useful to start with.
Dear Samer,
Thanks alot, I will do as you suggest!
Rgds
Deys
Dear Deys,
Would you kindly review the "Control and Monitor" processes in the PMBOK 4th edition.
PMBOK is the standard published by the Project Management Institute.
Depending on the division of work within your company, the projects are divided;
Design Stage
Construction Stage
Marketing (sales and rental) Stage
Facilities Management Stage
You will need to make sure that control each project then you can jump one step up to the Program (group of projects) control and monitor process.
I would recommend that you read the Project Management Book Of Knowledge, then you can read The Standard For Program Managment. Both by PMI. Applying the knowledge in these standards to your organization depends on your experience. Or you can hire experts with PMI knowledge to simplify the processes.
Samer
Dear Samer,
My companys business is real estate development. The procedures are not for any specific project but for project control for all projects for the company itself.
I joined the company about a year ago, from what i have been told, they hired independent consultants twice before and commissioned them to prepare procedures for them, but on both occasions they were not really happy with the results.
Right now we basically have a set of flow charts for some 20 procedures identified but some of these flowcharts are also not quite right.
I would like to know what is the best approach in establishing standard procedures for project controls.
Rgds
Deys
Deys,
Procedures are custom-made with company requirements.
In case you want to invest in books about project control,
you can start with this link from amazon.com
http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Daps&field-keywo…
Also, is this part of your roles and responsibilities? Dont push yourself too much if is beyond your reach.
R. Catalan
Dear Deys,
Can you please give us an idea about the field that your working in and the Project that you want to write a procedure for.
Thank you.
Samer
