invest or rental equipement !
8 replies [Last post]
Morph T
User offline. Last seen 17 years 44 weeks ago. Offline
Hi all
Generally speaking, don’t you think it is better to have your own equipemenet ( trucks, grader etc ) then to rental them, because if you are faced with a poor productivity, at least they are yours, it don’t harm to pay extra money to the internal “ logistique “ departement, anyway you are in the same company.
Any comments !
X Planner
User offline. Last seen 8 years 42 weeks ago. Offline
Well,
i think it depends on a physical analysis based on the expected risk (probability of ocurance) and the cost of ur project ( broken down into decision tree) so u could do a forward analysis to calculate the expected monetary value which is physical value will make u decide easier wither to buy or to rent.
John Lawson
User offline. Last seen 11 years 29 weeks ago. Offline
Not your English - my spelling at fault!!!
John
John Lawson
Hi Morph
I mean by a "separate company" - another Company / Division / Group - all depends on how you would like to structure the organisation.
This company would trade under as its own identity - under its own name - but would still be owned by the same "parent" company as the one that does the construction work.
Hope this makes more sense.
John
Morph T
ah ok
hell on my english
morph
Morph T
hi john
"a seperate company is set up to hire out labour"
oops, what are u talking about !
morph
John Lawson
Hi Morph,
In the UK a lot of the construction companies I have worked for have within their corporate structures a separate company that will both own and hire out plant and equipment. These hire companies will always hire to their own companies (Company policy), or can even hire to other companies, in some cases your compeditors!
When a new Contract is awarded within the group, the plant & equipment will always be hired from the "in-house" hire company. The same principle is used for supplying labour to a contract, when a seperate company is set up to hire out labour.
These companies normally buy the plant & equipment, usually at a compedative prices as they can bulk buy, and then hold it in their own yards / workshops etc,. When requested they will deliver to the prospective site, maintain and remove the equipment when the job is completed and take it back into storage.
Sounds nice, but the rates that I have seen used by the "in-house" hire companies can be very high, as they are not in a compeditive market. But these can be high due to the accountants moving money around within the company for tax benifits, as is the case of some companies I know!
If you thinking of this type of set up, you need to consider the financial benfits very carefully along with tax benifits etc., this is why I would recommend chatting with the company accoutant etc.
John
Morph T
hi jones
thanks, actually we are a general contractor who do all the work for ourselves.
"If you have a continiouse need for equipment (say Tower cranes, batching plants, scaffolding etc), it sometimes pays to set up a separate hire company to purchase and then hire the equipment to the project. (This can be good way of moving money from a project to other parts of the company)"
that’s exactly what I was looking for, can u explain more
regards
morph
John Lawson
All depends on what sort of a company you are and what sort of projects you work on, to tie up large amounts of cash on major plant & equipment that is only used for short periods is not good business sense.
The problem if you buy the equipment you will need to service, repair and store when not in use, well worth leaving this problem with a hire company, who will be set up to carry out the work.
However if you are doing a job like a dam, when the Dumpers, Scrapers etc. will be written off at the end of the work, then purchase will be well worth considering.
If you have a continiouse need for equipment (say Tower cranes, batching plants, scaffolding etc), it sometimes pays to set up a separate hire company to purchase and then hire the equipment to the project. (This can be good way of moving money from a project to other parts of the company).
Perhaps this subject is best for the company accountants to ponder, rather than the planners!!
regards
John
