Original duration change during Import.
8 replies [Last post]
Jenny Ingco
Dear All,
Why original duration changed when I import XER file and be not matching the start and finish date? I mean start and finish date show only five days but the original duration show 1 day.
Thank you,
HANSON
Jenny Ingco
Thank you very much for your help... No, It dosn't change and currently I am using "At Complete duration" instead of the "original duration" which I think its more accurate.
Thank you again,
HANSON
User offline. Last seen 19 weeks 1 day ago. Offline
Did the lag values, when other than zero also changed?
Anning Sofi
User offline. Last seen 6 years 48 weeks ago. Offline
Probably user preferences settings has changed.
Jenny Ingco
Thank you Gary and Roland for your quick help..
Ronald Winter
User offline. Last seen 4 years 16 weeks ago. Offline
Gary,
 Although I understand what you are saying, that statement is not entirely correct.  Looked at in a different manner, P6 Original Duration is a calculated field.  All data is stored in hours and when presented on the screen in units of Days, is converted using one of two possible conversion factors.
 If Hanson’s OD has changed, it is most likely that the conversion factor used is not the same as the one used on the other machine.  Good luck!
Gary Whitehead
Oriignal duration is not a calculated field. You can enter any value you like in it, and it will not affect your dates.
"At Complete" duration should give you the number of worknig days between actual start and actual finish
Jenny Ingco
Dear Sir,
Please, see the example below thats what I was trying to say.. Thank you,
Activity Name Original Duration Start Finish
XXXXXX 42 01-Mar-12 A 08-Mar-12 A
Gary Whitehead
Finish date is not calculated using original duration.
It is calculated using remainng duration.
