P6 to P3e - Is it possible?
David Craig 👤 Member for 16 years 8 months
Hi guys,
I was hoping someone would be able to assist on this small query of mine. I have been asked to put a programme together for a client of my employer. While reading through the contract, I seen a section that says the programme im putting together must 'Be constructed in Primavera P3e, as this is the *** ****** ******* ********** corporate planning tool, or in a format which can be readily and successfully read by Primavera P3e, such as Microsoft Project 2003 (or later versions).'
Now I have access to Microsoft 2007, Primavera P6.7 & Primavera P6 Professional 8.1. I feel a lot more confident using the Primavera software as opposed to MSP as i dont have much expereince of MSP.
Is it possible to use either Primavera P6.7 or Primavera P6 Professional 8.1 and convert this direcly to P3e?
Any help would be massively appreciated!
Kind Regards
David
David,
 You are in luck; P3e IS P6.  P6 used to be called P3e years ago when it was in Version 3.5, then Version 4.  Then came Version 5 (informally called P5) and then Version 6 (where it started being called P6.  With Version 8, it is now being called P6 Professional.
 You can open P3e XER backup files using either P6.2 or P6 Professional.  They are all the same program.  The specs requiring ‘P3e’ are just outdated.  Good luck!
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
