Converting Project Activity Codes to EPS codes
SSA Zaidi
User offline. Last seen 13 years 11 weeks ago. Offline
i have run into a new problem. I created a project with project activity codes(P6.2) . now i want to use the same codes for other projects in the same eps, so i tried to conver them to the EPS codes.
As soon as a project activity codes are converted to EPS codes, i loose their existing allocation in the project and my project becomes void of codes allocation.
is there any way around it?
Alfredo Jr. Hubilla
User offline. Last seen 5 years 43 weeks ago. Offline
When you make the activity codes to EPS codes, make sure you create a copy of that activity codes from the Project and that newly copied activity codes you can convert it to EPS codes and put it to your new project.
Hope this will help.
User offline. Last seen 24 weeks 3 days ago. Offline
I think your problem is relative to Group & Sort By.
Right Click on Projects window select Group & Sort By - Organized the projects accordingly.
Hope this will help
Frederic Fasquelle
User offline. Last seen 2 years 13 weeks ago. Offline
When you create EPS code, this belongs to node.
Projects you have created must be below this node.
