Start and Early Start
7 replies [Last post]
moutaz aldeib
Dear Planners,
What is the difference between Start and Early Start?
Moutaz
omid khan
User offline. Last seen 6 years 41 weeks ago. Offline
early start:
The earliest possible date the remaining work for the activity can begin.
This date is calculated based on network logic, schedule constraints, and resource availability. Early start dates can change as the project progresses and as changes are made to the project management plan.
  early finish:
The earliest possible date the activity can finish. Early finish dates can change as the project progresses and changes are made to the project management plan.
ef=es+duration
start(activities):
The current start date of the activity. For started activities, this is the actual start date. For not started activities, this is the planned start date until the project is scheduled. When scheduled, the start date field is set to the remaining early start date.
source:
p6 data dictionary 8.1
User offline. Last seen 32 weeks 6 days ago. Offline
If Data Date = Project Start Date then Early Start = Start
If Activity already Started then Start = Actual Start and Early Start is the start date of remaining duration.
If activity not yet started then Start = Early Start.
Ronald Winter
User offline. Last seen 4 years 18 weeks ago. Offline
Andrew,
Resource Leveling always puts its resultant dates into the Planned Dates columns.  It optionally also updates the CPM dates and the Start/Finish dates if you do not check the option, “Preserve scheduled early and late dates” in the Level Resources tab.  It takes a genius to keep all of these operations and options straight (especially because most of the operations are not even documented in the manual.)
Amit Parmar (PMP)
User offline. Last seen 12 years 42 weeks ago. Offline
Consider the following scenarios and see how the Start Date changes
1) Activity is not started --------      Start=Early Start
                                                FInish = Early Finish
2)A ctivity has an actual start -----  Start=Actual Start
                                                 Finish = Early Finish
3) Activity is Complete -              Start=Actual Start
                                               Finish = Actual Finish
Amit
Check out my blog on Primavera at http://www.primaverablog.in
Andrew Podolny
User offline. Last seen 2 years 4 days ago. Offline
One addition, Ronald. Resources Leveling also affects start/finish dates.
Andrew
moutaz aldeib
Could you give me an example of that?
Moutaz
Ronald Winter
Early Start dates are the result of the CPM calculation.  Start dates are a combination of Early Start and Actual Start dates.
