How to update Unique Fields using excel and importing back to P6?
Dear All:
Good day! I'm a beginner in using P6 and I have some problems updating the Units (Budgeted Nonlabor Units). What I am trying to do is to match the budgeted nonlabor units and the at completion nonlabor units in excel then import it back to p6.
Do you have any idea on how to update columns which are unique fiellds that has (*) in the column title? Thank you very much..
With best regards,
Voltaire
Z
Zoltan Palffy 👤 Member for 17 years
any column heading with an * are not importable back into P6
however non labor units at completion should be able to be imported back into p6
as Mike suggested it might want to look at the "Link Budget and At Completion for not started activities"
also run this global change
go to tools global change
new
where
calculate cost from units equals yes
then
calculate cost from units equals no
then select change on the right hand side
then select commit changes
now try the importing again
also go to the project directory make sure your project is highlighted
go to the calculations tab
on the rigt under resource assignments
make sure that
under When updating Actual units or costs  that
Subtract actual fro at completion is checked
M
Michael Lepage 👤 Member for 14 years 11 months
Hi Voltaire,
I understand what you are trying to do, but rather than trying to force it, I have another suggestion.
Open the project, go back to the Projects page, highlight the project, check out the Calculations tab.  There is a checkbox there called "Link Budget and At Completion for not started activities".
This, I believe will do what you're trying to do in excel.  It happens often, if you've imported a microsoft project file, that the budgeted and at completion units are not the same for not started activities.
As a beginner, you might also be interested in some Primavera tutorials at http://www.planacademy.com
Good Luck,
Michael
Featured Partner
Ashkan Mohammadi
Jeroen De Bauw
Senior Planning Engineer
Kristian Mcwilliams
dagogo dan - jumbo
xerxes
edwin
jhalluk69
