Printing P6 activities -level by separate pages
Alaa Al haj
User offline. Last seen 8 years 21 weeks ago. Offline
could someone tell me how to print the activities but each level in seperate page
i was  aple to do it in P3 but in P6 not succed yet
regards,
Scott Allerdice
User offline. Last seen 14 years 6 weeks ago. Offline
are these some kinsa tools or software to use for printing or just name of some useful machines to go for printing stuff? hubshout
kumar s
User offline. Last seen 9 years 27 weeks ago. Offline
Dear Neeraj,
ok then there is other way around
create a user defined feild text type (page break)
then select this in the columns of the actvities table.
then put the values in the coulmn
like if you want the 1st WBS in the first page then say it as 1 then fill down all the activities which are to be in this group
then for the second WBS type 2 and then fill down
repeat the same for all the WBS  like 3,4,5,
then after that go to group and sort select this user defined field (page break) in the top before the WBS .
then go to the font and color make the font size small and color as WHITE by this way you will not see this in the layout.
THEN PRINT set up options----page break settings -----click it
you will get the result...
Neeraj Agarkar
User offline. Last seen 6 years 26 weeks ago. Offline
kumar,
this doesnt work for me as it does not allow you to selectively break pages for certian WBS. For example, if I want only a page break for level 3, this method breaks at level 4 also.
Neeraj Agarkar
kumar,
kumar s
Dear,
if you are reffering to the WBS Level then you can get like this
go to grp and sort _ select wbs _untick the indent option
then go to print preview _page set up _ options _click page break every grp.
then you will get in seperate pages...
hope this helps .
