using different type of % complete for the same project
K
kumar s 👤 Member for 16 years 5 months
Dear all
i have a query regarding the % complete type for the activities
i have to  use the units % complete for 60% of activities (these activites are totally dependent on the resourceas available)
around 20% activities are based on the duration type(here resources does not matter only duration counts)
around 10% activities are dased on physical % complete(the actitites should be assessed by the % scope finished)
SO IF I USE these three % complete type in a single project what should be my settings while updating the schedule
i wanted to known if the percentages will show correctly when it is rolled up to the wbs level.
please guide me
thanks in advance
K
Dear Amit
thnaks for your reply
so you mean to say that hte weightages cannot be given to the activities.
i have a doubt about the Est weight option for the actitities
what is the use of this. can we not assign the weightages here for a set actitivities which are coming under a  perticular WBS Node.
can you please brief me how can  we assign resources in values on weightages.
Amit Parmar (PMP) 👤 Member for 15 years 7 months
HI Kumar,
You are correct when you say that the weightages can be assigned only at the wbs level to wbs milestones. But we use a workaround by assigning resources in values on weightages and updating the activities based on that. But it works if only the weighted resource is updating the activity.
Amit
K
Dear Amit
Thank you very much for your valuable input.
i will work on it by creating a sample project and analyse it
one more thing i want to know if we can assign weightage to a perticular activity.
i thought that weightages can be given only at the WBS LEVEL only
Primavera has following columns:
1) Duration % complete
2)Units % Complete
3) Physical % complete
Each of these columns will show you rolled up values in wbs for the respective type of activties. ie. If a WBS has a mix of duration, units & pysical the rolled up values for these activties will be in their columns and you would not get a combined rolled up percent complete.
In order to get a combined % complete, you have to add column "Performance % complete" which at activity level :
Performance % Complete = Activity % complete (Activity Level Only)
In order for the value to roll up to wbs level the project should have a cost loaded baseline assigned to it. Cause WBS level performance % complete is calculated by the following formula
Performance% Complete = Earned Value/ Budget at Completion
I know this is confusing so i would suggest tht you make a simplet project with 5 activities of different types and assign cost to it and you would autmoatically see the percent commplete getting rolled up into a percentage.
Note- If you have weightages fo these activities with you, then i can suggest you an alternate way to get rolled up percentages.
Amit Parmar
Trian Asmoro
Soheil Barekat
Erkan Polater
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
