Unknown Error while opening P6
Irfan Khan
User offline. Last seen 5 weeks 1 day ago. Offline
Hi to all,
While opening P6 below mentioned error is coming. How to solve this ?
"The database has not been configured to run background jobs. To correct this problem, please contact your System Administrator or see the Promavera Administrator’s Guide: Lat System Monitor Job Run : 19 Jul 2010 15:53:40:000, Last Data Monitor Job Run : 19 Jul 2010 15:53:40:000.
Pls sombody help,
thanks.........
Peter Gable
User offline. Last seen 4 years 15 weeks ago. Offline
I think you will find a fuller answer in ID 905203.1 from the Oracle Knowledge Base.
Irfan Khan
thanks Rodel i got it.........;)
User offline. Last seen 6 weeks 6 days ago. Offline
Irfan,
If you are using standalone, check if the SQL server or Oracle server is running on Task Manager. If not then you have two options.
Option 1: Restart the computer and make sure SLQSERVR is running.
Option 2: Select Start-> Settings-> Control Panel-> Administrative Tools-> Services. Look for SQL Server (Primavera) and double click. Click start if the status is not started.
If you are using Network Server, check the network and you may not connected or ask your IT if SQL Server is down.
