Show number of resoures in activity column
Rodel Marasigan 👤 Member for 19 years 9 months
Vaughn,
Sorry for misunderstanding as you mentioned columns and not label. If label you wanted as per Roger advise use UDF and populate using Global Change then assigned to a bar. You can always run Global Change to update if resources change.
Hope this help.
V
Vaughn Edwards 👤 Member for 18 years 2 months
I understand how to get Budgeted Unit/Time to appear in the Activity and Resource windows, what I’m looking to do is see a column in the Gantt view of the number of resources assigned to that activity.
Vaughn,
If using Resource Window, right click and select columns-> Customize.
Under General you can select Budget Unit/Time and Remaining Unit/Time.
If using Activity Window select Resources tab. Right click on Resources table and select Customize Resource Columns. Under General select Budget Unit/Time and Remaining Unit/Time.
Roger Booth 👤 Member for 19 years 9 months
I use one of the user defined fields and then attach that UDF to the bar. Gives you a display very similar to dare I say Microsoft Project
V
Thanks for your reply. I have found the number of resources under the resource and activity windows, but the budgeted Unit/Time isn’t available to choose to inset a column. Thats my problem.
Vaugh,
It is now on Resource Window (P3 don’t have before) and called Budgeted Unit/Time for Budget units and Remaining Unit/Time for Remaining Unit. It is also available on Activity Window Detail-> Resource tab.
Featured Partner
mxsiegel
Mattvtek
Gareth Evans
PP Admin
Rajkamal Tangirala
Rahul Kumar
blake333_
Jeamiell Ostrovsky
Hamzah Ahmed
Quinton van Eeden
