print out calendar
Izam Zakaria
User offline. Last seen 7 years 32 weeks ago. Offline
Guys,
Sorry for asking this, how to print out the calendar in P6?
Anbin Ponnith
User offline. Last seen 8 years 17 weeks ago. Offline
Tim
Anbin
Tim Readman
User offline. Last seen 28 weeks 5 days ago. Offline
Izam,
better than a work around use comviz which looks into the database and get the out put from there. I have wanted P6 to do this like we used to do in P3 but in the end had to get one produce.
http://comviz.com.au/products/comvizcalendar
"Comviz Calendar automatically calculates working days depending on the start day. These days do not include non-working days from Oracle Primavera P6 and the days marked as non-working. You can assign different colors and labels for the calendar days in order to create sofisticated calendars."
Tim
Joel Villanueva
User offline. Last seen 12 years 19 weeks ago. Offline
Hi Izam,
Here’s a workaround to print out calendar: go to enterprise –calendar, choose calendar name then left click modify button.
Once the calendar pop-up appear; execute print screen on your keyboard then paste and modify it into powerpoint to show only month calendar. Repeat same process if you want to print your whole year calendar. It’s a bit tedious but it works.
Joel
muhammad anwar
User offline. Last seen 4 years 6 days ago. Offline
Groups: TILOS
Izam,
P6 does not provide the facility to print calendar but workaround to show by putting a long bar at the top of your plan and using necking to show non work periods.
regards
Muhammad
