Problems in cost loading in Excel sheet
Haresh,
You can include WBS name when you export data into excel. When you run the export-> spreadsheet-(xls) and reached select template, click modify and select WBS name under general. There is a forum that I explain how to import cost into Primavera using export/import spreadsheet-(xls). I believed either Option 2 or 3 is appropriate for you to use. Instead duration use your estimated cost.
Duration Percent Complete Post #3
henrigpc
Hashil Ali
Nigel Hussey
