How to get decimal digits in Budgeted units
14 replies [Last post]
Anbin Ponnith
User offline. Last seen 9 years 32 weeks ago. Offline
Dear All,
How do I get decimal digits display in the Budgeted Units Column.In the Bottom Layout section - Resource tab-Budgeted units Column,I tried to get it display in decimal.But I could not do it.Please help me out.
With Thanks & Regards,
Anbin Ponnith
User offline. Last seen 9 hours 2 min ago. Offline
edit users preferences
Currency Options
check Show decimal digits
Abdul Muqueed Moh...
User offline. Last seen 3 years 41 weeks ago. Offline
Dear Anbin,
I am also facing the same difficulty. Kindly advise the solution for displaying decimal digits in budgeted units.
Mohamed Baset
User offline. Last seen 8 years 15 weeks ago. Offline
go to Admin - Currencies - select you currency,
go to Appearance then Number of Decimal Places (use 2)
2 decimals is the max
Ali Pandidan
User offline. Last seen 4 years 33 weeks ago. Offline
it just shows two digits
ehat if I need more that two digits?
Ali Pandidan
Sayed Elyas Kawish
User offline. Last seen 7 years 37 weeks ago. Offline
All,
"Budgeted Total Cost" column in P6 v.7 is not showing the amounts in at least two decimals. I've tried Edit/User Preferences/Currency/check mark the "Show decimal digits"
But, it shows 0 after checking the mark.
Any help is appreciated!
Sayed Elyas Kawish
All,
Chigullapally Anand
User offline. Last seen 14 years 24 weeks ago. Offline
To all
How to display thousand seperator (,) in Primavera (Release 6.0)
Anand
Dieter Wambach
User offline. Last seen 8 years 27 weeks ago. Offline
Dinesh
I’m afraid this isn’t possible. Just checked the pm.ini file of version 7 to find an entry to modify without result. I don’t know any place force P6 to show thousand separators for units.
Dinesh Kumar Dama...
User offline. Last seen 9 years 41 weeks ago. Offline
How can I show thousand separation in the budgeted units same like budgeted cost.
Thanks & regards
Izam Zakaria
User offline. Last seen 8 years 46 weeks ago. Offline
go to user preference - time units and set decimals points
Hi there,
COuld you tell me on how to do that.
Thanks & regards
Anbin Ponnith
Thanks for All,
I found the solution.
Anbin Ponnith
