Bearing Negative Total Float if Apply Must Finish date
Cecil Soliva
User offline. Last seen 7 years 33 weeks ago. Offline
Hi Planners:
I made a project having an early finish date of October 15, 2010 and the same I provided to the project details must be finished on October 15, 2010. I found out that the Total Float of the critical Path changes from 0 to -1. How does P6 reads with this regards?
Thank you,
Cecil
Arnold Puy
User offline. Last seen 10 years 12 weeks ago. Offline
You are welcome.
Cecil Soliva
Thanks again Arnold..I’ve wasted a lot of time, thinking how it became -1 TF..
regards,
Cecil
Arnold Puy
Hi Cecil,
Try to check the finish date.
1. Go to Edit --> User Preferences --> Dates tab, Time, tick Show minutes and select the 12 hour (1:30 PM).
2. Go to Enterprise --> Projects
2. In Projects Detail Tab --> Dates
3. In "Must Finish Date" if you notice the the time is 12:00 AM, change this to 4:00PM or 5:00PM. It depends on the calendar and time you use.
Otherwise, check your finish date. It should be the same with "Must Finish Date especially the time.
Arnold
