Cut-Off’s in P6
Jonathan Ward
User offline. Last seen 13 years 18 weeks ago. Offline
Good morning/afternoon al,
Once again, any help that anyone could would be very much appreciated. How do I ’create’ or ’set’ a cut off (by date) in P6?
Many thanks
Jon
Ronald Winter
User offline. Last seen 4 years 8 weeks ago. Offline
Jonathan,
After applying actual dates and status, you need to have P6 re-compute the CPM using the ‘cut-off’ date as a status date. In ‘P6 speak’, this means that you want to re-calc [push the F9 button or select “Tools / Schedule”] and set the data date to the fist day that new work can begin. Then press the schedule button. There are a huge number of options (this is where P6 shines.) The Help button on the schedule window will be a big help to you. Good luck!
Anoon Iimos
User offline. Last seen 3 years 17 weeks ago. Offline
have you tried "store period performance"? and what does your baseline shows?
Jonathan Ward
further to my original question below,, in P6 are the ’Timesheet Date Adminsitration’ options the same as ’cut-off’ dates that can be allocated in P3?
I’m after a method of freezing the data to the left of the datadate line (obvuiously once this has been processes and finalized)
many thanks
