Calculated user-defined fields
Rajesh Khanna Sake
User offline. Last seen 3 years 26 weeks ago. Offline
Is there any way we can insert a user defined column and assign a formula to it to calculate its values in Primavera P6?? I know there is such an option in MSP but I didn’t find one in P6.
Rajesh
Rajesh Khanna Sake
I was actually trying to calculate "Calendar Days" - I could assign a formula to the user-defined field and it is working fine at the activity level. But, at the WBS summary level - it is adding up "calendar days" associated with all the activities in that level which I believe is incorrect.
Is there any way we can change the way the summaries are rolled up just for the user defined fields?
Many Thanks,
Rajesh
Ronald Winter
User offline. Last seen 4 years 31 weeks ago. Offline
The web-based P6 has calculated fields but this feature is not in the Client/Server version.
Rajesh Khanna Sake
Thank you very much !!!
mimoune djouallah
User offline. Last seen 6 years 13 weeks ago. Offline
you have to use global change for that.
HTH
