P3 Activity Codes to WBS
7 replies [Last post]
Sampath Lakshmi N...
User offline. Last seen 5 years 34 weeks ago. Offline
Dear Guys...
You people are rocking in this forum..And adding dignity to our profession...Hats Up...
Can anybody help me import activity codes from P3 to create a WBS Structure in P5/6
warm regards
Narein
Arnold Puy
User offline. Last seen 9 years 25 weeks ago. Offline
Hi Sampath,
If you are familiar with this, "PATTLNK_632006_536-xerFileParser&Builder.xls" then you can easily convert your Activity Codes into WBS.
Arnold
Thank you Mr.Mike
Thanks for your valuble information.
Warm regards
Lakshmi Narayanan
Michael Ridino
User offline. Last seen 14 years 39 weeks ago. Offline
I have done this a dozen or so times and the best way I found is to print out an activity code summary and recreate the old coding in the WBS. Cut and paste the activities into the correct buckets and your done.
I have yet to find a way to do it automatically.
Mike
Thank u Mr.Shazad,
I already asked my contractor to do it. But in the mean while while I am in the process of searching a short cut to do it.
Thank u very much for ur response
Narayanan
Shahzad Ahmad
User offline. Last seen 15 years 3 days ago. Offline
Hi Narayanan
you can ask to your contractor to change WBS in P3 show all activity under WBS bands.
after that if you will convert your P3 sch. in P6 or P5 it will not crate any problem.
I always confirm during kickoff meeting to my contarctor if they are using P3
all activity should be under WBS Bands plz do not assign activity code to acivity later on it will be create problem while convert P3 in to P6 or P5
shahzad
You are perfect...
My situation is Different.. I am working as a project manager. My Consultant and contractors are using P3 and I feel like using P6. So only I want to convert the P3 files into P6. Because when I use pert master the appearence is not looking good...
Thanks for ur response
Solo Ma.
User offline. Last seen 6 years 46 weeks ago. Offline
hi
sorry to say this but, are you lazy working in wbs?
p6 wbs is now a flexible one to work with.
activity code is like an assistant to filters in p6 nowadays.
