P6, How Can I Modify Existing Reports Wizards?
Abeer Mahmoud
User offline. Last seen 8 years 42 weeks ago. Offline
At P6, Kindly note that when I modify columns/sort and group at existing reports wizards and save it
I must establish report format again font/header/cells/row titles…etc
How can I avoid this loop?
Abeer
Ferdinand U.
User offline. Last seen 7 years 31 weeks ago. Offline
Show time in the dates
Ferdinand U.
Ardee Tarun
User offline. Last seen 13 years 4 days ago. Offline
can anyone help me with my problem. When I copied the projects into cd and as I opened it to another computer, the total duration has  changed and -1 float appeared. How does it happened. By the way, I only did export XER file
Abeer Mahmoud
Hi Ahmad,
It is a very good idea I will try it I promise.
Abeer
Ahmed Elkordy
User offline. Last seen 16 years 3 weeks ago. Offline
hello abeer
if you edit a report using the report canvas you can do ANYTHING and save it....
but
if you use the report wizard with a saved report then all that you’ve done using the canvas is lost..
my advice is....practice using the canvas...it is INFINITELY FLEXIBLE and forget the wizard
