P6 Standalone - Excessive SQL lag?
9 replies [Last post]
Eric Rivera
User offline. Last seen 7 years 11 weeks ago. Offline
Hello all!
I am having an issue with P6 when working in a LOCAL database. When I open PM and select the database on my laptop (not the company server) and attempt to open any of the projects stored there, it seems to take FOREVER... When I look at my computer system resources, it shows SQL using over 1/2 the CPU.
EVENTUALLY the project(s) will open, sometimes after 30 minutes or more. Others tell me that they don’t have any lag at all.
Has anyone else had a simmilar experience, and if so, how did you over come it?
Eric
António Faria
User offline. Last seen 9 years 11 weeks ago. Offline
You could also try this (update statistics in SQL Server Express):
http://www.planningplanet.com/forum/forum_post.asp?fid=1&Cat=8&Top=44886
It worked with me.
António
Andrew Podolny
User offline. Last seen 1 year 1 week ago. Offline
Here is another script to reindex all tables with fill factor 90%:
USE pmdb$primavera --your database name might be different
DECLARE @TableName varchar(255)
DECLARE TableCursor CURSOR FOR
SELECT table_name FROM information_schema.tables
WHERE table_type = ’base table’
OPEN TableCursor
FETCH NEXT FROM TableCursor INTO @TableName
WHILE @@FETCH_STATUS = 0
BEGIN
DBCC DBREINDEX(@TableName,’ ’,90)
END
CLOSE TableCursor
DEALLOCATE TableCursor
Isagani Culaway
User offline. Last seen 12 years 13 weeks ago. Offline
good day,
Is anyone here knew how to install the P5 software cause my friend have one but we could not install the P5. May be anyone of you have an idea to install this and run it properly.
send me to my email if you know.
engr_gans@yahoo.com
Arend Kok
User offline. Last seen 10 years 28 weeks ago. Offline
No Problem!
David Kelly
User offline. Last seen 1 year 50 weeks ago. Offline
Arend Kok
Hi David,
You can run this script to produce the script that will rebuild all indexes :
set head off pagesize 0 echo off verify off feedback off
spool reb.out
select ’alter session set sort_area_size = 36000000;’
from dual
select ’alter index ’ || index_name || ’ rebuild;’
from user_indexes
spool off
set head on pagesize 35 verify on feedback on
@@reb.out
Thanks to Guri Singh
Sr. Oracle DBA
David Kelly
Arend,
You don’t have a similar script for the full V5 on Oracle?
Arend Kok
Eric.
Have you tried rebuilding your indexes.
I run this script on my database regulary. It keeps it really fast.
Here it is :
DECLARE @Database VARCHAR(255)
DECLARE @Table VARCHAR(255)
DECLARE @cmd NVARCHAR(500)
DECLARE @fillfactor INT
SET @fillfactor = 90
DECLARE DatabaseCursor CURSOR FOR
SELECT name FROM master.dbo.sysdatabases
WHERE name NOT IN (’master’,’model’,’msdb’,’tempdb’,’distrbution’, ’mmdb$primavera’)
ORDER BY 1
OPEN DatabaseCursor
FETCH NEXT FROM DatabaseCursor INTO @Database
BEGIN
SET @cmd = ’DECLARE TableCursor CURSOR FOR SELECT table_catalog + ’’.’’ + table_schema + ’’.’’ + table_name as tableName
FROM ’ + @Database + ’.INFORMATION_SCHEMA.TABLES WHERE table_type = ’’BASE TABLE’’’
-- create table cursor
EXEC (@cmd)
OPEN TableCursor
BEGIN
-- SQL 2000 command
--DBCC DBREINDEX(@Table,’ ’,@fillfactor)
-- SQL 2005 command
SET @cmd = ’ALTER INDEX ALL ON ’ + @Table + ’ REBUILD WITH (FILLFACTOR = ’ + CONVERT(VARCHAR(3),@fillfactor) + ’)’
EXEC (@cmd)
END
CLOSE TableCursor
END
CLOSE DatabaseCursor
DEALLOCATE DatabaseCursor
All this will do is rebuild all indexes for all tables in your database.
Hope this helps.
Arend Kok
Dieter Wambach
User offline. Last seen 7 years 12 weeks ago. Offline
Eric
Did you a backup and restore?
Did you run (in P6) Tools --> Check Project Integrity?
Did you check the event log?
I assume your pc has sufficient performance and your project below one million activities - or 4 GB.
Sorry just questions, no answer. It seems something wrong with the database.
