refreshing data from database
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
Raviraj
Basically you are right. There is an entry in the ini-file. As I heard from Primavera that they put more and more information into the ini-file and in P7 want to be independent from the registry I checked and found this entry as well in P6.1. I tried to get an information on the entries, but without success - Ill keep on trying. Youll receive this description as soon Ive got it.
Sorry for a wrong information.
Hi Dieter,
From my admin, i dont have any response.
But, i have checked PM.ini file, wherein there are two settings for auto refresh
AutoRefresh=False, And
AutoRefreshInterval=300000
Am i supoposed to change this to TRUE and what @ this interval; is it for a user??
Rav
Thanks Dieter,
I wil check with my admin.
Raviraj
It depends on your installation of the database. There should be some settings of parameters at least in Oracle; you should ask your DBA. Sorry, I didnt work with database settings for about 10 years, forgot many things and the products changed as well.
Thanks Dieter, but in simple words, does it mean that whenever i INSERT or DELETE it will refresh automatically?
Raviraj
Refresh is done by the database and depends e.g. on the cache. The only exception are "F5" and in general the commands "insert" and "delete" ("update"). Another factor is your net. How to influence the frequency of refresh you should ask your DBA (database admin). As far as I know it is not influenced by Primavera.
Hope this helps
