P5 Batch Reporting
Oliver Melling
User offline. Last seen 5 years 21 weeks ago. Offline
Groups: The GrapeVine
If i am using the job service function to run batch reports, is there a way to run reports against individual portfolios?
In the job service dialog box you can select which project the reports are run against.
In reports you can’t select a portfolio as a filter object.
Can it be done?
K D
User offline. Last seen 16 years 19 weeks ago. Offline
Hi.
How about filter Project ID. I can not check it whether that field is availble, cause I do not have the server here.
Dieter Wambach
User offline. Last seen 7 years 44 weeks ago. Offline
Oliver
I don’t know a way to run batch-reports against a portfolio and quite sure that no internal means can provide it.
