Fill Cell Function in P3, lost in P6?
Anoon Iimos
User offline. Last seen 3 years 25 weeks ago. Offline
fill down in P6 is different from fill cell in P3, i’m currently using P6 and i don’t know how to assign activity codes faster - the way i’m doing it in P3...any help would be appreciated
Anoon Iimos
thanks, i use global change and it works, now i’m falling in love with P6
Dieter Wambach
User offline. Last seen 8 years 11 weeks ago. Offline
You can make it work similiar to P3:
First select an activity with the correct value. Then select those to be changed together with the Ctrl-key!! If you’ll use the Ctrl-key there is no need for the activities’ sequence. Pay attention for the correct column.
If you’ll use the Shift-key, P6 will take the topmost value and fill the other cells.
