P3 User
J
John Raper 👤 Member for 22 years 2 months
Some fundamentals:
P3 - One database, one project. (Allbeit 23 files!)
P5 - One database, all projects.
The biggest change to get used to is filters and layouts.
You don’t have four layers of filter, only one. But you then combine several filters.
In P5 Layouts are global, so if you have text in a footer relating to one project then you need to save the same layout again for a different project. I have this problem with saving the revision record.
In P6 layouts are project-specific, though I have yet to get upgraded to P6 so I haven’t seen how it works yet.
Dieter Wambach 👤 Member for 19 years 6 months
Hi Jonathan
in a previous job I accompanied some users during their migration. Like everything: if you consider before what you are about to do, there will be no problem. Establish the structures before you’ll start to migrate projects.
Nevertheless there are some mines:
1. The structures:
- EPS, with e.g. the heritage of access rights
- Resources: Hierarchical, no "*" or "?"
- OBS / Responsible Manager as a team, not a person
2. Layouts and filters
3. Algorithm for levelling
4. Global change
5. Reporting: superiour, but different
6. Codes.
7. P5/P6 completely adapted to WINDOWS standards
8. More performant PC required.
9. Different usage of calendars
On the documentation CD you can find an excellent PDF "Moving from P3 to P3e"
It will be easier than you imagine.
Good luck!
Good
M
Mark Chapman 👤 Member for 20 years 2 months
> flying with it in a matter of weeks
I guess you are thinking about your next contract? In which case a couple of weeks is too long if you said you were proficient in p3e.
I had p5 installed on my desk when we were using P3. I went in and took a look and it was totally alien. Even the most simplest task was initially difficult to solve.
I think after about a week of no help I was getting up to speed but I still had loads of burning questions.
So I would be honest and declare you are a P3 user but don’t anticipate moving to p3e being a problem.
N
Niek Zonneveld 👤 Member for 21 years 4 months
Jonathan,
I was a fairly proficient P3 user, until eight years ago when I switched to P3e.
I found the switch quite easy to make and never took any training.
The biggest trap you can fall into as far as I’m concerned is to assume that P3e should behave the same as P3. It’s an entirely different application that does many of the same things in a different way. If you don’t waste your time on spotting the differences, but just concentrate on how P3e works, you’ll be flying with it in a matter of weeks.
H.T.H.
Niek.
Featured Partner
Gareth Evans
PP Admin
Rajkamal Tangirala
Rahul Kumar
blake333_
Jeamiell Ostrovsky
Hamzah Ahmed
Quinton van Eeden
Sunchana Johnston
Akram Hammam Mohamed
