Filtering act. with value in user defined field?
6 replies [Last post]
Almas Ahmed
User offline. Last seen 15 years 5 weeks ago. Offline
Hi, How to filter the activities which has a value in the user defined field?
Almas Ahmed
Thanks Ian,
Ian Nicholson
User offline. Last seen 15 years 14 weeks ago. Offline
Once a UDF is created in in the Acivities view, it is available as a filter criteria. For text UDF’s, you will probably have the most success using "Contains" as the selection criteria instead of "equals" since there is no validation of UDF’s.
A common mistake is to make the UDF in the wrong module (like WBS) instead of Activities and then it won’t be available to filter on.
Ian
http://www.emerald-associates.com
User offline. Last seen 32 weeks 5 days ago. Offline
Hello Lead Management
Whoever or what you are if you wish to contribute to the PP forum then please do so as an individual.
As and when you do contribute at least make it meaningful.
Not many regards as yet.
Mike Testro.
LEAD MANAGEMENT
User offline. Last seen 15 years 20 weeks ago. Offline
Groups: GPC Qatar
Good Luck,
Lead Management- Qatar
Almas Ahmed
Thanks samer,
I posted this Q in Forum P5/P6....
I have just moved it - best regards Mike Testro.
Samer Zawaydeh
User offline. Last seen 6 years 19 weeks ago. Offline
Dear Almas,
You need to post this in under the correct category; depending on the software that you are using.
Try to use the help menu option in your software often.
With kind regards,
Samer
