Vista compatibility!!
6 replies [Last post]
Suraj Bhatt
User offline. Last seen 10 years 34 weeks ago. Offline
Hi all!
I am having problems in installing P5 stand alone on Windows Vista.It always says "Bad user name for SQL"
when I try configuring the database.
Is there a database conflict with Vista??
Need info!
Suraj
vikas agrawal
User offline. Last seen 5 years 39 weeks ago. Offline
Yes! Vista does not support P5.0 database. The PMDB uses MSDE database for standalone applications. However, if you upgrade your MSDE database to full blown MS SQL Server 2000 (or higher version) then there will be no problem in use with Vista.
vikas agrawal
Marc Borburgh
User offline. Last seen 11 years 28 weeks ago. Offline
The problem is that P5 uses an MSDE database for stand alone installes. Vista doesn’t support MSDE and P6 will have MS SQLServer 2005 delivered with it for Vista support.
P4 doens’t use MSDE, so that might work on Vista.
Suraj Bhatt
Thanks!
So does it mean that I can install P4 on Vista but not P5?
Ronald Winter
User offline. Last seen 4 years 7 weeks ago. Offline
I suggest that you read an earlier thread on this subject at http://www.planningplanet.com/forum/forum_post.asp?fid=1&Cat=8&Top=25812. Good luck!
Charleston-Joseph...
User offline. Last seen 3 years 40 weeks ago. Offline
Hi Suraj,
I think better use P3 in XP environment and MS Office 2003.
Also be wary of MS Office 2007.
Joseph
Dieter Wambach
User offline. Last seen 8 years 1 week ago. Offline
You’ll have to wait for P6.
P5 doesn’t work under Vista
