Total float
Rodrigo Brazil
User offline. Last seen 5 years 5 weeks ago. Offline
Hi all,
Is there any way to keep the total float positive when you use "must finish by"?
Rodrigo
Kevin Button
User offline. Last seen 3 years 28 weeks ago. Offline
Be very careful when using a Mandatory constraint as it ignores all network logic.
KB
User offline. Last seen 24 weeks 6 days ago. Offline
Hi Rodrigo,
Using Mandatory Finish as your constrain will remove your total float even you have float originally before constraining your activity. If you used mandatory finish dated earlier than schedule then you will have a negative float. This required changing your logic to override your negative float and change it back to 0 float.
Rodel
