How to Create a New Database in P5?
Neil Atkinson
Trian Asmoro
Soheil Barekat
Erkan Polater
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Thanks Arthur
From CD1 select install other tools/server databases/create a new Primavera database. Deselect the default option to include sample project data. On the next screen select the project database option. On the next, the option to create d/b and load app data. (And load the licence file.)
Two screens later, just change the default PMDB name, and the data file and log file field addresses will change automatically. Now youre on a roll.
I would like to keep the sample database too for reference... I have the admin guide on the install CD... Ill look through that.
Thanks guys!
Brennan
Use the demo installation disk again it give you the options of just set up the database.
HTH
If you need more help, you know how to contact me...
Alex
If you want to start from scratch, the instructions are in the adminguide.pdf file on the documentation CD. Unfortunately I cant email it to you because it is too big (about 8.5Mb).
If you have to keep the existing database, once your EPS and projects are removed, just go through each item on the Enterprise menu and remove anything you dont want. This should be quicker than creating a new database anyway.
yeah, I am after a clean start
Deleting the EPS is a start, but that will not remove global data such as Resources, Activity Codes, Filters, Layouts, Reports, Calendars and probably a few other things.
U can open the database that contains the sampled data u have created then delete all the data that u put in there (by deleting the main EPS).
After that u can put your company data into that database.
Regards.
