Gantt Chart
P
Paul Garland 👤 Member for 20 years 6 months
Much of it depends on your settings, however try the following. Create a calendar with 24hr working and make sure the little box work hours/ day has 24 in it.
Assign it to your activity. Your settings may show the duration in days & the admin preferences may be set to an 8 hour day, therefore as you enter 1d, you get 00:00 to 08:00. Unless your administrator can set your default hours per day to 24, you will have to enter the equivalent 8 hour days the show 31-Oct-06 00:00 to 01-Nov-06 00:00 (3d) or enter 24h directly.
Your user preferences can be changed if you want to show the hours worked.
T
Tu Huynh Van 👤 Member for 19 years 11 months
Hi Paul,
Thanks for your infor,
but i mean that:
examp: activity 1 - duration: 1 day (08h), the Bar normaly will be show from 08:00am to 17:00 pm - this is OK, what the solution for this one if we want to show this bar for the whole day: from 00:00am to 24:00
Please advice,
Tu,
P
I’m not entirely sure what you mean, however if you go to edit > user preferences > and select the Time Units tab, you can set the unit of time to a day rather than by the hour. Also set the decimal places to zero so it will not allow a fraction of a day?
That may do what I think you’re looking for.
Hope that helps
Paul
Alex Wong 👤 Member for 23 years 4 months
Dont understand your question please give a bit more info
Mohammed Netarwala
Moahmed
S Z
Iftikhar Awan P.Eng.
ahmad rashidi
paulciszewski
Catalin Suditu
Laraib Fatima
Adrian Fletcher
GeoVe
