Print layouts to HTML file
Hans Seuters
User offline. Last seen 18 years 44 weeks ago. Offline
I send several layouts to a HTML file using "Tools, Publish, Activity Layout." I receive the error message "Cannot create output file" and "writing png file failed" How can I solve this problem. Thx.
Hans Seuters
I had restricted acces. Thanks for all the replies. It is solved now.
By the way, I am not working for Shell.
Nigel Hussey
User offline. Last seen 18 years 21 weeks ago. Offline
Hans, if you are in the Netherlands is it safe for me to assume you are working for Shell? If this is the case then you have a Shell GI-D machine which will have a bunch of restrictions that will create problems when using this feature. As Arthur says check your restrictions. Use the following path "C:\APPS\", this directory has no restrictions on a Shell GI-D enabled machine and should work fine when using this feature of Primavera.
Mario Sanvitale
User offline. Last seen 13 years 24 weeks ago. Offline
When printing to an html file, if the file already exists you have to be sure it’s not already open, I believe, as you can’t overwrite a file in use - when I publish I usually delete the target file first. I’ve seen similar messages when the target file was open.
Arthur Godbeer
User offline. Last seen 16 years 1 week ago. Offline
Do you have unrestricted write access to the location and directory to where you’re exporting? And enough disk space?
