Customer sized paper on plotter
Hans Seuters
User offline. Last seen 18 years 16 weeks ago. Offline
Is it possible to plot on a customer sized paper format instead of using the standard format like for example A0?
I am using the HP Designjet 1055CM and like to print on a larger paper format then A0. It is possible to do so using MS Projects but Primavera did not give me the possibility yet.
Hans Seuters
Thanks, this helps. :)
Nigel Winkley
User offline. Last seen 37 weeks 17 hours ago. Offline
Groups: The GrapeVine
Hans
I am using an HP 5500. In the plotter preferences you can set your paper size to be custom, say 1 metre x 7 metres. Then in P3e set the printing preference to use the plotter, custom paper at the size you set up in the plotter preferences.
So in Windows printer setting, preferences, set paper size. In P3e set plotter and paper size.
Works for me
Good luck
Nige
