Filtering by Activity Codes in P3e
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
Emmanuel
David is right, you need to create activity codes and values first coz the one that you have right now is only a code in the user defined field, thus when filtering only the activity descriptions apear and no band grouping your activities...
Cheers!
Christian
Emmanuel
It is NOT possible to make a filter ask you for the value. When you run a filter in P3e it must have the value(s) you are looking for specifically coded in the filter - so for example a filter to select activities by the phase of a job cannot ask you "which phase" when you run the filter, you will require to create one filter per phase.
The primvera product SureTrak has this capability, and is very usefull.
Mario,
When i run thet filter I expect the filter dialogue box to display the code values/ descriptions for me to select from.
