Define/Create New Methodoligies for Project Archit
Forum Guest
User offline. Last seen 42 weeks 1 day ago. Offline
Does anyone know how to define/create, (not alter the WBS element) new base methodologies for use with the project Architect.
i.e. say i wanted to replicate a project based upon a standard corporate WBS.
Jim Fairchild
User offline. Last seen 11 years 41 weeks ago. Offline
You can create new base methodologies in Methodology Manager by exporting an existing project in P3e and then importing it into MM. When you import the project you are given a choice on whether to use Actuals or Planned values for the existing project.
This is actually quite neat because you have a chance to improve your methodologies after they have been used - continuous improvement.
Jim
Forum Guest
Project Architect is used to Import a Methodology from Methodology Manager into Project Manager.
You can either create a project through PA or import a Methodology into an exicting project.
H.M.PANCHAL
INDIA
panchalhm@rediffmail.com
