Projects in Project table not displaying on P3 Scr
Thomas Leahy
User offline. Last seen 9 years 17 weeks ago. Offline
All,
When I run the following SQL statement
"select * from project where (orig_proj_id is null and base_type_id is not null) or (orig_proj_id is not null and base_type_id is null)"
I shouldn’t get any records returned. However I get 302 records returned 299 with an orig_proj_id and no base_type_id and 3 with a base_type_id and no orig_proj_id.
The projects do not appear in the normal P3 screens. Any recommendations on what should I do?
Tom Leahy
Shirish Borkar
User offline. Last seen 18 years 9 weeks ago. Offline
299 records with orig_proj_id and no base type id - are baselines so anyways will not be shown on P33 screen.
3 with a base_type_id and no orig_proj_id - indicates that baselines restored as projects. These three should appear on screen as project. Have you done any other thing at backend? Have you applied any filters? Something which you could remember.
