Delayed Data using Primavera SDK
Voltaire Taguinod
User offline. Last seen 20 years 31 weeks ago. Offline
I am trying to add activities to P3e using VBA via SDK. However, after having done "insert into task (wbs_id) values (xxx)", it takes exactly 30 secs for the new activity to be reflected in P3e client (by doing F5-Refresh).
How do I decrease this delay?
I have tried setting "DelayedLoadMode=off" in PMSDK.ini, but this doesnt do the trick.
Any ideas?
Gaultz
Bernard Ertl
User offline. Last seen 10 years 22 weeks ago. Offline
Gaultz,
Its possible that you are not supplying enough parameters.
I use the following without any timing problems:
INSERT INTO TASK(task_id, wbs_id, task_name, target_drtn_hr_cnt, duration_type) VALUES ...
Bernard Ertl
InterPlan Systems Inc. - Project Management Software, Project Planning Software
Kevin Button
User offline. Last seen 3 years 20 weeks ago. Offline
Gaultz,
The SDK contains a number of stored procedures, one of which is commit_changes. Try executing this procedure after inserting a task and see if it makes any difference. I dont know if this will work but it may be worth a try.
Kevin
