P3 Layout
Ahmed KHR
User offline. Last seen 6 years 42 weeks ago. Offline
Dear planners;
Is it possible to loose layout configuration on P3? If yes, how?
Regards.
Ismayil Mammadov
User offline. Last seen 12 years 6 days ago. Offline
Ahmed,
i understand you, it is problems of P3, u can do nothing if it happens except go do fix command on the programm - go to P3WINS/P3PROGS and run PFXW file. otherwise  You need just go to previous saved layout and work again.
BR,
Ismayil
Manoj VS
User offline. Last seen 9 years 6 weeks ago. Offline
If any changes happend to your layout that is not required you need not save the layout. You can reopen the previously saved layouts.
With regards
Manoj
Ahmed KHR
Hello Ismail;
First, Thank you for anwers;
I think I didn't explain my question, The pobleme is not how to delete layout, but my problème is sometimes I loose some characteristics (Bars colors, ...).
Regards.
Ismayil Mammadov
Dear Ahmed,
You can simply delete the Layout you want, or delete/change the filtr. As i understand you want to delete any layout.
to go: view-layout-delete, and choose any layout you want to delete.
if it is not you want then please specify your need
BR,
Ismayil
