How do I view resource usage across all projects
Stephen Phillips
User offline. Last seen 8 years 46 weeks ago. Offline
I have a number of resources which I don’t want (probably carried in during imports). When I come to delete them they are in use but I don’t know which projects they are being used by. Is there a way of showing this without having to open all projects together?
Ronald Winter
User offline. Last seen 4 years 17 weeks ago. Offline
Stephen,
The reason that no one has answered is due to the nature of your question: P3 does not have ‘global’ resources. P3 resources are defined within the schedule and do not affect other schedules. If you are using P3, you should not be having this problem.
Are you perhaps referring to P6? There you question would make more sense. If so, you might try asking your question in the P6 forum. Good luck!
