TO ASSIGN CALENDAR ID BY ONE CLICK
vex zex
User offline. Last seen 14 years 3 weeks ago. Offline
HYE...
I HAVE QUESTION HERE.hOW TO ASSIGN CALENDAR ID FOR JUST ONE CLICK...
LETS SAY WE HAVE 1000 ACTIVITIES USING THE SAME CALENDAR?
AFTER THAT REQUIRED OTHERS CALENDAR TO ASSIGN FOR THE 100 ACT.
hOW TO ONE CLICK CALENDAR TO EACH ACTIVITY WHITHOUT INSERT ONE BY ONE
vex zex
Ok..thanks
Mervilyne Pangan...
User offline. Last seen 2 years 15 weeks ago. Offline
Hi Vex,
Go to Tools --> Global Change --> Add --> Modify
in
Data Item: put CAL(stands for CALENDAR ID),
Criteria: EQ
Data Item/Value: choose your calendar
then click Ok and RUN...all your activities you want to change will be change and if you want to change some activities in different zone, you have to filter it first.
User offline. Last seen 4 days 21 hours ago. Offline
Vex,
Show Calendar ID column on Activity Window. Change the Calendar ID of the first row. Highlight all rows that require update or use filter then right click and select Fill cell.
