assign calendars to many activities in one step
6 replies [Last post]
Abeer Mahmoud
User offline. Last seen 8 years 47 weeks ago. Offline
Dear all,
Can any body help me to assign calendars/durations....etc to many activities in one step? As we used to do in p3 by fill cell command where is this command in p5?
Thanks.
Hamed Najmzadeh
User offline. Last seen 8 years 40 weeks ago. Offline
Dear All
how we can insert new project with different calendar in existing project in primavera?
Sincerely Yours
H.Najmzadeh
Syam Mohan
User offline. Last seen 6 years 50 weeks ago. Offline
Hi everyone,
                  The Start date and finish date is not matching according to the duration given. calendar assigned is same for all activities. Can anyone tell me the reason for this wrong dates.
Abeer Mahmoud
Thanks for all of you it works.
Abeer Mohamed Taher
Riyadh Yahia
User offline. Last seen 13 years 4 weeks ago. Offline
Hi Abeer,
To add a calender in one step, try this:
1- Add calender Column from Column (General Option.
2-Add desired Calender to First activity on Top of the Column.
3- Point the arrow on empty Calender Cell at the Bottom of the Calender Column.
4- By using(SHIFT + UP ARROW) OR (SHIFT + MOUSE POINTER) highlight the activities From bottom to Top......upto the assigned calender.
5- As you Reach the Assigned Calendr, make Right click choose Fill Down.
you can use same way to add any item.
best regard
riad
Arnold Puy
User offline. Last seen 10 years 14 weeks ago. Offline
Hi Abeer,
You can assign calendar for the existing activities using GLOBAL CHANGE.
Calendar = "Select Calendar"
If you wanted to change the selected activities only then you need to filter prior to run Global change.
Arnold
Hannes de Bruyne
User offline. Last seen 2 years 35 weeks ago. Offline
Did you try Edit->Fill Down (CTRL+E)?
