P3 Installation for Windows 7 (64bit)
11 replies [Last post]
SAIFUL ADLI MOHAMAD
User offline. Last seen 14 years 42 weeks ago. Offline
Hi all,
I’m having difficulty in installing P3 to my new PC which using Windows 7 (64bit). My PC prompted me saying that P3 is not compatible with this OS.
Can anyone help me on this? Will really appreciate your help..
User offline. Last seen 23 weeks 1 day ago. Offline
as I stated previously p3 will not run on a 64 bit operating system.
You must first install virtual xp fof windows then install p3 there
http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
Robert Victor Gam...
Windows 7 allows you to build an XP 32-bit Virtual Machine where you can install P3.
In Win 7, use XP mode.
In Win 8 Pro or Enterprise, use VM Manager to create a VM. Install XP SP3 on the Virtual Machine and you can install P3 on it.
Arturo Aleman
User offline. Last seen 13 years 33 weeks ago. Offline
Hi, anyone knows if primavera project planning does run on windows server 2008 x64? the version is 8.1, thanks.
mostafa sharf
User offline. Last seen 13 years 35 weeks ago. Offline
thanksssss very much
SAIFUL ADLI MOHAMAD
Thanks a lot David..
BTW, I’m already switch to P6.
Bye2 P3..
David Molan
I’m new to Planning Planet and Primavera 3.
I had this same problem and was considering buying an old laptop with XP as couln’t see a way of running P3 on win 7 64bit.
SureTrak installs ok in compatibility mode which is great, P3 doesn’t.
There is a solution!!
Win 7 has a Virtual Win XP software. I have Win 7 Home edition which this is not meant to work on. There is a work around solution to this:
http://www.mydigitallife.info/2010/05/13/how-to-setup-and-get-xp-mode-on...
When you have installed the virtual XP it runs XP in a window like there is another computer there. P3 installs perfectly with this.
I havn’t tried experimenting further too much as only discovered this solution last week.
Hope this helps,
David
Mike Miller
User offline. Last seen 12 years 37 weeks ago. Offline
P3 will not install or run on Win 7 64bit whether you are using compatibility mode or not. Do not waste your time... it won’t install no matter what you do. The only solution is to dual boot with win xp
User offline. Last seen 13 weeks 1 day ago. Offline
Mohamad,
Try this and it may work. I haven’t try this to Window 7 (64bit) but work fine on window vista (64bit).
Install P3, additionally, you must complete the steps below to register a required DLL file.
1 Open a command prompt.
2 Change your directory to the location of the “ra32.dll” file. By default, the path is C:\Program Files\Common Files\Primavera Common\Ra.
3 Execute the following command: regsvr32 ra32.dll
Good Luck
