To all Experts
Z
Zq qz 👤 Member for 23 years 1 month
just use your old method, but instead of WK1....wks....just leave it blank....
oki doki.
moutaz
I had a good experience with Excel; it opened the file with the fields under different cells. Then I could run an Excel filter very easily.
There are many ways to skin a cat, you should use the one best fit you.
M
moutaz aldeib 👤 Member for 22 years 6 months
Dear Rafeal,
Thanks so much for your response and your offer.
I managed to open it through DBF, however, the results I got are not the same as I convert it through WK1 and WKS.
Moutaz
Moutaz
The DBF format can be read by Excel 2007, just it will not open it automatically.
You have to either:
1) Right click on the dbf file, select open with, and choose Excel.
2) You can set up your system to open DBF file extension with Excel automatically.
You can download the movie, there you will see the file format is in DBF and that it was opened using Excel 2007, you will recognize 2007 ribbon.
To unpack the file you might need some utility like IZArc, you can downoad it from the foloowing link.
izarc.org
I have no much work for the moment so if I can be of any help don’t hesitate to ask for more assistance if you wish.
I am also to try Dieter suggestion as another avilable alternative, although I still believe with a right click and open with Excel saves you a step. Note that the wks conversion utility does not work with Excel 2007, that there will be a stand alone utility but is not avilable yet.
M
Dear Rafael,
Thanks for your response.
the DBF format is not supported by excel 2007, consequently can not be opened.
Moutaz
Featured Partner
xerxes
edwin
jhalluk69
wilmoahyi
Peter Holroyd
Robert Guers
Jerry Robinson
Elyar Safarov
Our Partners
