Exporting to WK1 format
JAGAN REDDY MUSUKU
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Hello Kannan,
what do you mean by "not appearing in the wk1 format"? are you using Lotus 123 as a spreadsheet? wk1 is the file format for this software that was #1 spreasheet before Lotus Corp decided to surrender in front of MS and to switch to the Lotus Notes family
MS Excel (until 2003 included) will open a wk1 easily, and you will be able to save the file as a wk1 file afterwards
you could also use the MS Excel files that are found on the P3 cd-rom; they are full of good macros that will make you able to work in MS Excel and import / export your P3 data directly.
Alexandre
