Primavera Import: exported 1 line for the format, but copy and paste of "format" to the dates below does not work.
John Reeves
User offline. Last seen 23 weeks 12 hours ago. Offline
Primavera Import: exported 1 line for the format, but copy and paste of "format" to the dates below does not work.  It will not produce the black triangle in the upper left like the real exported dates  which states "Text Date with digit year" and when I copy the date format it turns the dates into excel dates in number format.  2nd question, does putting a ' mark in front of the id - is that enough to make it importable.  I have imported on and off for years - I just forget the nuances.
User offline. Last seen 23 weeks 3 days ago. Offline
you cant import start and finish dates those are claulated
you can import constraint dates
you  can import actual dates
1st export 1 activity of what you want thne use that as a template to import it back into p6
