Hello All,
I have been reading the forums for a while but joined to ask a question.
I looked through all 10 available pages of posts and I did a search for multiple users but couldn’t find the answer.
I have Primavera P3.1 and I have a single schedule for a construction project. Myself and another schedule would like to both work in the P3.1 schedule to add activities, manhours, and logic at the same time. We have setup a network shared folder off the server and both have access to the schedule. We can both pull it up, but when we both try to access the schedule the second try gets an error saying the schedule is already in use.
What is the best way for 2 (or more) people to work on a single schedule through the network in P3?
I also tried to use the check in check out feature of p3.1 and it copies a set of the files to my computer locally and then lets me work with the file, but when my coworker tries to get to the schedule after I have checked it out, he gets an error. I assume that is the point of check in check out, and it is working as it should, but we need to both work on the file at the same time then merge the input.
On a side note, I think there should be a separate forum for P5 and P6 posts instead of combining them in a P3 section of the forum.
thanks,
Teague
Novice Scheduler
