Activity ID
16 replies [Last post]
moutaz aldeib
User offline. Last seen 3 years 6 weeks ago. Offline
Dear Planners,
Could you tell me how to use activity ID or what is the difference between activity code and activity ID?
Moutaz
Ali Farhat
User offline. Last seen 14 years 21 weeks ago. Offline
Dear Ernani or Muhammad,
can you forward me the mail please
pasteur_78@yahoo.com
many thanks in advance
Ernani Garena
User offline. Last seen 12 years 48 weeks ago. Offline
Dear Waqas,
Can you also send me example in which I have to import resources from excel to P3?
Also, please send me step-by-step procedure on exporting data from P3 to excel.
Thank you very much in advance!
Ernani
Ernani Garena
Dear Waqas,
Thank you very much for your response!
Ernani
Muhammad Waqas Zafar
User offline. Last seen 11 years 7 weeks ago. Offline
Dear Ernani,
I have mailed you three seperate mails having three steps to understand import/export featuer with help of small example.Please note that:
You must install MS-xcel 2003 in your computer as no other X-cel will take that
Please dont open mail of next step until you undersatnd previous
Waqas
Ernani Garena
I want to learn and understand the process in import and export data from excel to p3 & vice versa. Can you email me the step-by-step process. I would like to explore more P3 since I am new with planning.
My email address is ernan0518@gmail.com
Dear Moutaz,
I exactly understand what’s ur confusion is. The Activity ID tab adjacent to the Activity Codes tab can only be useful if you know and using import/export feature available in primavera.
In import/export feature one can import/export data on x-cel sheet in DBF or WK1 ....etc formats.This is done by the intelligence building of Activity ID’s on x-cel sheet and configuring the ID’s in Activity ID tab that when you import data in p.3 all the activities fall in relevant heads.When you are using import feature than you don’t need Actvity codes to build.
Its appearing complex but once you have learned how to do it !than you may never use Activity Code approach.If you need to ask more; do please let me know.
Waqas
Dieter Wambach
User offline. Last seen 7 years 32 weeks ago. Offline
Moutaz
Activity ID is an identifier and must be unique. To address a specific activity, you’ll have to do it by the ID.
Code is is a classification and identifies a group of activities. An activity may be classified by: Construction phase, compressor A, area B7, responsibility sub "XX". Later in reports you can analyze by area, phase, responsibility, equipment.
There is a speciality for P3 because it was written a time when harddisk space and memory was extremely expensive: Out of the activity id you can use up to ten digits for four codes where the first two are reserved for the project id.
Was this an answer to your question?
moutaz aldeib
Hi Fernand,
you may not get my point, even with activity code you can organize and filter data.
Moutaz
Ferdinand Fincale...
User offline. Last seen 9 years 6 weeks ago. Offline
Hi Moutaz,
As per the P3 help, may I just reiterate a line in my previous posting, "Activity ID codes can be used for organizing and filtering data in the layout and in tabular reports and graphics." I think that’s the whole point of that Activity ID Tab in relation to the Activity codes.
Try to have some exercise to know more on how it goes.
Ferdinand
moutaz aldeib
Alexandre,
I am sorry I could not get your point, could you explain in more details?
Moutaz
moutaz aldeib
Hi Alexandre,
I do not mean activity ID in the column area, I mean activity ID tab in the activity code.
Moutaz
moutaz aldeib
Thanks Ferdinand,
I read this script in P3 help, but what I mean if we use activity code which I always use it, what is the need to use activity ID?
Moutaz
Hi Mr. Moutaz,
Here’s a script from the help content of P3:
"The Activity ID tab enables you to classify activity IDs in ways that are meaningful within your project. For example, in a project that is part of a group, the first two characters of each activity ID are reserved for the SUBP (Project ID) code; this enables you to sort and summarize activities based on these codes.
Activity IDs can contain up to 10 alphanumeric characters, which can be divided into a maximum of four codes. Activity ID codes can be used for organizing and filtering data in the layout and in tabular reports and graphics."
Activity ID denotes a particular activity in your program, while the Activity Code refers to the coding system of your Activity ID for its usefulness as explained above.
Hope it explains its difference.
Ferdinand
