Graphic Reports Probleme
Aytac Erdogan
User offline. Last seen 16 years 15 weeks ago. Offline
Hı everyone
I am having problems with P3.1 when ı try to get graphics reports. I receıve the error named "unexpected file format". even though ı reınstalled P3.1, this problem still occurs.
Is there anyone who faced the same problem? What am ı supposed to do? Plese ınform me.
Roli Rafa
User offline. Last seen 16 years 26 weeks ago. Offline
Hello,
If SP3 doesn’t solve your problem, here’s my advise.
I surmise that you log into a network before you open your P3. It this is the case, then you should first go to Localadmin, that is using your PC without logging into the network, then on the Windows Explorer, go to P3WIN directory, then right click, on the pop-up, go to Properties. Under security tab, add your network user ID and check all the boxes that will give you full access to the directory including its subfolders . Then login to your network and hopefully your problem would be solved.
Roli
A D
User offline. Last seen 4 years 15 weeks ago. Offline
Aytac Erdogan
No, How can I get it?
Ronald Winter
User offline. Last seen 3 years 50 weeks ago. Offline
Have you installed Service Pack 3?
