P6 - Users tracking log
Carmen Arape
User offline. Last seen 7 years 47 weeks ago. Offline
Hi All
Does anyone have an idea about Users tracking log in P6.
We built an EPC schedule split in 4 different schedules. One schedule is full dedicated to procurement. This is the heart of the 4 units for which 4 different schedules comprise Engineering and construction. The 3 planners have defined links between engineering – procurement – construction.
As we update on monthly basis, we experiment all type of errors such as: deleted links or link lag.
Does P6 have an option where someone can track what a planner has been doing in the procurement schedule (the heart of the EPC multi schedules).
Thanks & Cheers,
carmen
Dieter Wambach
User offline. Last seen 8 years 11 weeks ago. Offline
Yes Alex you are right. Because we use MS-SQL server I forgot this option. May be in MS 2005-server this option exists as well. I didn’t check.
As for the Primavera database, a layout of the data model is delivered as a pdf - in P5 and P6.1 not in P6. Among the documentation files Primavera added a layout of each table as a html.
The trace option for each client - under the user preferences - I never checked.
Good luck Carmen!
Alex Wong
User offline. Last seen 12 years 15 weeks ago. Offline
Groups: TILOS
But you need a Oracle/Primavera DB expert to assist.
Alex Wong
Groups: TILOS
In P6 you can have the full log and track down who did what and when. as long as you don’t overwrite the log file
Alex
Dieter Wambach
Carmen
As far as I know this is just possible per table: Who and when - update_date and update_user - but not which modification.
You can read it with SQL.
Regards from Germany
