error - user is logged on
7 replies [Last post]
doyin mcarthur
User offline. Last seen 4 years 27 weeks ago. Offline
I am using a standalone P6 v16.2 and cannot get logged on after my computer crashed.   I keep getting error message that 'user is logged on'.
Any advice on how to clear this?
Cynthia Stiffler
User offline. Last seen 2 years 48 weeks ago. Offline
I am having the same issue. Can you forward me instructions on how to fix?
User offline. Last seen 9 weeks 6 days ago. Offline
send me your email address and I will forward detaled instructons
User offline. Last seen 33 weeks 3 days ago. Offline
<--Duplicate post-->
Doyin,
The issue is that, due to the computer crash, the user session that was last used hasn't been closed, and therefore P6 thinks that user is still logged in. You have to be able to connect to the database and modify some of the records - in this case delete the user sesson record.
Luckily as you're using SQLite, its somewhat easy, you can use a tool like DB Browser for SQLite to view and modify SQLite data tables.
Follow these instructions on how to use the DB Browser: http://www.p6academy.com/index.php/n111-primavera-p6-with-sqlite-and-sqlite-browser/
And the Scripts you need to run to delete the user session record is shown here: https://deepinthecode.com/2018/06/29/primavera-p6-session-hung-on-oracle-database/ you can use the same commands.
doyin mcarthur
I am using Windows 16299 and on a SQLite as the database. There is no error code except when I logon I get username is already logged on and I cannot get in
Bian Mutang Tagal
User offline. Last seen 2 years 15 weeks ago. Offline
Hi Doyin,
Which Windows are you on (7, 8, 10)
Are you using SQL Server or SQLite as the database, if SQL Server then which version?
can you give the error code if there is one
