export resource usage spread sheet in p5
GeoVe
JAGAN REDDY MUSUKU
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
can u do the favour the same to me,...
with regards,
Mr. Ameen N Pasha,
[email protected]
I am really thankful to both of you.
I am able to do it now.
Thank you once again
Mubashir
I try to give you a step by step guide. HTH
1. Open Your project
2. Then Click assignment
3. Change Timescale @ the spreadsheet to month or week
4. Highlight the activity
5. Click Ctrl C
6. Open Excel
7. Click Ctrl V
That should work
ALex
Mubashir
reporting in P5 is very easy. Try it.
Print resource usage profile:
View "Activities" --> "resource usage profile" --> File --> "Print Preview" --> "Page Set-up (The Icon upper left corner) --> walk through the detail tabs --> "Options" mark "Resource Usage Profile"
i still unable to do it, one more query sir: how to print resource usage profile??
Mubashir
P3 and P5/P6 are different programs, not just two different versions of the same one. So, many algorithms and procedures are different.
The way to produce and then save a report for export to EXCEL is rather easy. The produced format is csv and you can set a parameter that Excel automatically opens after the data was produced - the report ran. We produce most of our s-curves this way - just run the report. I dont miss the P3 ability.
Just try it.
Dieter Wambach
Thanks for your reply, you are right but i guess in P5 we can not export "Resource Usage Spread sheet" in excel format. Where as in P3 we can get such outputs in formats like csv or wk1.There it used to help me in production of S-Curves with lot of flexibility.
Please Comment
Mubashir
Youll create a report with "Time Distributed Data" marked from the group Resource Assignments (or a similiar name). Then youll be guided by the wizzard. As output format youll select text/ASCII-file.
